Keyless Entry
Old Dec 13, 2006 | 07:45 PM
ernie22golf's Avatar
Default Keyless Entry
I just bought a 1995 Cpe and the clicker I call them came with the car but appeared broken. The part where it would connect to a key ring is broken off and it was apart with battery and both sides. I put it back together again with the battery in and it opens the hatch with no problem and when I push the doors the interior lights come on and the passenger door will unlock but not the driver's door and the security alarm doesn't seem to be working. Any ideas on this. I'm going to try to reprogram tonight and see if it will work any better.
Old Dec 14, 2006 | 09:19 AM
Default RE: Keyless Entry
More than likely, you have a problem with the remote keyless entry module. I am assuming that your power door locks both work manually with the interior switches. GM has had problems with the module. Without proper test equipment, that one might be hard to diagnose. [8D]
jargusLT4
Dec 3, 2007 06:10 PM
Devo
Sep 25, 2006 11:39 PM
jsjodin
Aug 26, 2006 01:03 PM
jndnaps
May 13, 2006 12:11 AM
mtsumedi
Dec 14, 2005 01:55 PM
