Passive Keyless Entry
Old Aug 9, 2006 | 10:00 AM
jargusLT4's Avatar
Default Passive Keyless Entry
The passive keyless entry system and the remote hatch on my 1996 LT4 stopped working after I reconnected the battery. When I try to reprogram it following the steps in the owners manual, I can't even get the PKE light on the dash to come on, nor does it come on when I first start the car. I checked all the fuses on the panel inside the passenger side door and they're OK. Seems like there's no power going to the receiver. I changed the battery in the transmitter but that didn't help. Any suggestions?
Old Dec 3, 2007 | 05:48 PM
toby11's Avatar
Default RE: Passive Keyless Entry
Did you ever find out what was wrong? I'm having the same problem. I have a new control coming. Hopefully it was the old control. Mike
Old Dec 3, 2007 | 06:10 PM
Viscount's Avatar
ORIGINAL: jargusLT4
I assume you have the programming instructions for the PKE. The ignition shud be in the "run" position & then the "lock" position. Sometimes it's possible to getthe key in the wrong place.
There are 2 fuses for the PKE-#26 & #40.
Just a couple of thoughts.....I would check to make sure there is power on both sides of the fuses in question.
Grouch C4
May 22, 2008 08:01 PM
Little Moe
Feb 19, 2008 12:49 AM
larry00
Jun 7, 2007 09:58 PM
jndnaps
May 13, 2006 12:11 AM
mtsumedi
Dec 14, 2005 01:55 PM
