loss of radio and headlight power at same time
Old Dec 24, 2006 | 06:26 PM
vetterfl's Avatar
Default loss of radio and headlight power at same time
does any one know what the cause might be . my son drove my 85 from florida to pa with no problem then at the end of his trip the problem occured . luckily it was daylight when it happen but the radio and the headlights lost power at the exact same time .he replaced al the fuses in the panel. but nothing .any help wuold be appreciated MERRY CHRISTMAS TO EVERYONE
Old Dec 24, 2006 | 06:50 PM
PAY2PLAY's Avatar
Default RE: loss of radio and headlight power at same time
Welcome to the site. I'm going to move this down to the C4 section where you may get a better response.
Old Dec 24, 2006 | 11:28 PM
Have you checked power on fuses with a test light? Migh have lost a fusible link off the post behind the battery. [8D]
Old Dec 25, 2006 | 12:42 PM
gorichb's Avatar
Yea
a fusible link was to the first to come to my mine.
Old Jan 9, 2007 | 04:43 PM
vetterfl's Avatar
I want to thank Mech259 and Gorichb for their great input it was the fusible link at the starter again thank you very very much
Old Jan 9, 2007 | 04:49 PM
vetterfl's Avatar
i have a nother problem I put new dist. cap and rotor,plugs and wires on the 85 and now it seems to stumble when you give it gas . also there is a sticker on the inside of the hood telling me the gap should be .030 not .045 for the plugs can anyone tell me what deal is with that . it seems to run the same at either gap
Old Jan 11, 2007 | 01:12 AM
Did you set timing on car? If you did, did you unplug the connector then set the timing. Because if you didn't then the timing will be retarded. Also, you might have cracked an insulator on a plug causing a misfire.
Old Jan 11, 2007 | 01:15 AM
Specs are:
Canada .045
US .035
[8D][8D][8D]
Corltone
Apr 15, 2007 07:24 PM
chargedvette02
Nov 14, 2006 02:51 PM
frank j
Nov 11, 2006 12:34 PM
dcd58
Nov 24, 2005 01:21 PM
