Low Coolant light keeps coming on.
Old Aug 7, 2020 | 05:24 PM
KoolKell's Avatar
Default Low Coolant light keeps coming on.
Hi Guys, My Low Coolant light keeps coming on in my 1988 Vette. When I check the Radiator its always nearly full. I top it off, The Light goes off and comes back on in about 10-15 minutes.
Today the Coolant temperature is running between 225 - 240. Yesterday the Coolant Temp ran between 196 - 210..... any ideas? Thanks
Old Aug 8, 2020 | 07:58 PM
Welcome to the forum. If those temperatures are accurate, the first thing I would do is replace the thermostat.
The intermittent low coolant light might be caused by a faulty sensor. Since I don't know how their sensor operates, it's hard to troubleshoot. If it's not too expensive, you might just try replacing it.
Old Aug 8, 2020 | 09:35 PM
hcbph's Avatar
And I'll be you checked the level ever time with the car cold and off. Good move but won't find the issue that way as it's always higher in the radiator that way. Get a tester to pressurize the cooling system, AutoZone rents them and HF sells them. Pressurize it to about 15 psi and leave it there and see if it holds pressure (I doubt it will). If you are using Prestone green style antifreeze, it fluoresces under black light.
One area to look is the hose between the block and the TPI. I had one that cracked and a pinhole sized leak, hard to find till I did the above.
Old Aug 9, 2020 | 01:45 PM
KoolKell's Avatar
Thank you, yes I check the coolant level in the Radiator before I start driving when the engine is cold. Thanks for the feedback Pressureizer.
Old Aug 9, 2020 | 01:47 PM
KoolKell's Avatar
Thank you. Can Thermostats be adjusted so that the fan comes on at a lower temperature?
scottcolbath
Sep 7, 2014 10:31 PM
kuladog
Jan 21, 2011 09:08 AM
joz06
Dec 2, 2007 08:27 PM
GrampsC4
Oct 15, 2007 11:56 AM
GrampsC4
Sep 19, 2006 09:48 AM
