New headliner (snappics)...
Old Jul 30, 2014 | 07:38 PM
Default New headliner (snappics)...
My headliner was sagging. I did this once on a '94, with school logo embossed onto new felt.
Had the How-To posted here, but it was before the server upgrades a few years ago.
This was the old one:
So again here:
I put a butter knife to the edge, to get under it. Make sure to hold the knife flat on the edge, to not scratch...
Then you can get a hand in.
Old Jul 30, 2014 | 07:52 PM
Once you get under the edge, ya' gotta' pull the fabric off of the panel with your fingers. Don't try to pull it by the edge of the foam board - it will break up.
Wear long sleeves!
Go all the way around the edge, then work toward the center.
(at this point, the edge DID break, and I had to go around the other way)
Lifted. Lots of glue at the center.
I'm goin' with C4 logo this time, instead of school logo. I have a couple more of these, if anyone wants one here; PM at me.
Old Jul 30, 2014 | 08:01 PM
Once the old felt is removed, I put a roller with Acrylic Latex Black to the foam pad, to stop dust from falling through the felt, and to give a little strength to the pad.
I also glued a 3/16" styrofoam board, cut into sections, to the roof panel side of the foam pad. I'm looking for noise absorption too with 3" exhaust, and a HEAVY drone.
Then I placed the felt, and flipped back the felt to apply glue to the lower half (using this for adhesive -
Then the top half,
and allowed it to dry overnight.
DO NOT PRESS DOWN TOO HARD - THE ADHESIVE WILL COME THROUGH THE FELT. You could see that in the 'Skully' '94 top...
Old Jul 30, 2014 | 08:09 PM
Then flip it, and cut about 3" around the perimeter.
The forward corner concave curves are tricky. I made 2 cuts in the apex of the concave curve, to about 3/8" of the edge.
Flipped; check interior surface:
(same snappic, #3, post 2 above)
Now back up-side down, pull the tape, and glue the overlap...
Old Jul 31, 2014 | 01:52 PM
Glue the lip to the panel side - I'm using RTV Black:
Re-tape, allow to dry, then set the pad into the panel.............
Old Aug 1, 2014 | 02:02 PM
Done.
Felt glue onto the roof panel:
and set into place:
I did not cut the overlap deep enough into the front corner concave curves, and I got an ugly buckle on the D side.
And I placed a 3/16" styrofoam board glued onto the panel side of the pad, for extra exhaust drone kill. I have a glass top too, so I can measure interior sound with that top, and then again with the insulated Black top (when the rain stops)...
Aug 16, 2014 09:56 PM
Aug 7, 2007 11:33 AM
Jul 3, 2007 06:46 PM
Charcoal C4
Mar 20, 2007 06:43 PM
ernie22golf
Dec 1, 2006 10:37 PM
