Oil Change light question
Old May 8, 2008 | 02:00 PM
dale's Avatar
Default Oil Change light question
on my 1994 vette, the change oil light came on, I should still have about 600miles left before the suggested mileage comes up by the oil change sticker. Is there any way to turn light off? Does the car have a different oil change milage or usage counter ? Any help?
Thanks
Dale
Old May 8, 2008 | 03:53 PM
trespasser8's Avatar
Default RE: Oil Change light question
Dale,
I have a 95 which I am assuming would be the same. If you did not reset the change oil light at your last oil change then it can come on any time. To reset: turn key to on-engine should not be running, press the ENG/MET button, then within 5 seconds press and release the ENG/Met button again, then within 5 seconds press and hold the GUAGES button, the CHANGE OIL light should flash, hold the GUAGES button until the CHANGE OIL light stops flashing and goes out! (Haynes Repair Manual 1984 thru 1996)
Old May 8, 2008 | 08:18 PM
Viscount's Avatar
http://www.idavette.net/
Old May 8, 2008 | 09:43 PM
dale's Avatar
thank y'all for the help
Dale
Old Aug 29, 2015 | 11:09 AM
cleteschuessler's Avatar
experiencing the same issue on my 94 coupe. However it will not reset. Tried 3, or 4 times using the steps in the manual. Any help is appreciated.
93c4matt
Sep 23, 2008 02:50 PM
93c4matt
Sep 17, 2008 12:16 PM
delaughter68
Nov 21, 2007 06:33 AM
bigjohn
Apr 4, 2007 12:04 AM
joecls
Apr 18, 2006 11:57 AM
