Passenger-side door panel removal
Old Aug 20, 2007 | 10:18 AM
zach562's Avatar
Default Passenger-side door panel removal
Hi I sure could use some help I am replacing the dreaded outside window seal I have done the driver's side and I'm now working on the passenger side however I cannot seem to remove the door panel, I have removed a screw hidden behind the courtesy light and a screw behind a door lock.
But it still does not seem to want to come off as if something is holding it near where the power window switches is,
is there anyone out there that can help me with this?
Old Aug 21, 2007 | 07:57 AM
LeesVette's Avatar
Default RE: Passenger-side door panel removal
Yep. There is a screw behind the power window switch.Pop the power window switch out and get a flashlight and look behind it. It sits in the hole for theswitch way back there. It connects to a little bracket that is connected to the door panel. The driver side does not have this screw.
Dzbo
Dec 29, 2012 10:33 PM
Baudier
Jun 19, 2008 10:27 PM
july349
Oct 14, 2005 07:27 PM
july349
Oct 8, 2005 02:01 AM
Wifes81
Aug 12, 2005 12:28 AM
