no first gear in automatic
Old Jan 4, 2021 | 04:07 AM
apeaton's Avatar
Default no first gear in automatic
my 1999 will not start out in low gear. I have to manually put it in low and then it only goes to 2nd. shifts to 3rd and 4th. what did I need to check to find the issue. thanks...trans has been rebuilt just before I got the car but has had the issue ever since Ive had it. just got the ls1 rebuilt to 383,
Old Jan 15, 2021 | 09:55 PM
74HARLEY's Avatar
No first gear, may be a bad shift solenoid. However if the trans was rebuilt you may want to check and make sure it's actually the correct one for your car. Some transmissions are only suitable for their exact year/ make/ model.
Old Jan 20, 2021 | 08:01 AM
apeaton's Avatar
replaced shift solenoids still no low gear, scanner said it is commanding 1st gear. any help would be greatly appreciated
Old Jan 20, 2021 | 11:37 AM
74HARLEY's Avatar
Well that's not the good news we were looking for. From here the options really narrow because you have the command for first gear. Let's try the only simple one first.
you need a comprehensive wiring schematic for the trans. You will need to verify that the signal for 1st gear is getting all the way to the trans. Sometimes the wires just fail.
Saying you have signal at the trans, your next options become the valve body or a bad band or clutches.
There could possibly be other avenues to look at but we're getting above my pay grade here. Good luck and keep us posted.
CorvetteNate48
May 5, 2018 06:30 AM
bobslsc
Mar 21, 2013 04:32 PM
08 Jetstream
Apr 11, 2008 12:25 PM
Vack
Jun 2, 2007 10:15 AM
Pecemkr
Aug 5, 2006 04:43 PM
