Blower fan and windshild wipers not working
Old Oct 30, 2007 | 08:21 PM
anzolv's Avatar
Default Blower fan and windshild wipers not working
Hello All : First time here this a great forum for vette owners and wanabees. The windshield wipers and blower motor stop working when I close the driver side door. I replace the door coutesy light switch on the door but they still cut out. any Ideas anyone. This is a 81 vette.
Old Oct 30, 2007 | 09:34 PM
pg's Avatar
Default RE: Blower fan and windshild wipers not working
Hi and welcome to the forum.
On my 74 when you open the door the switch completes the circuit to ground and the lights go on.
I would trace that switch wire and see if its what else is hooked to it.
My wipers have two seperate ground wires-a black wire from the WW to a bolt on the bell housing and a seperate ground under the dash for the wiper switch.
Mabye the PO was Bubba and the wires were put together.
Hope that helps, PG.
Old Oct 31, 2007 | 02:09 PM
DeeVeeEight's Avatar
Banned
I agree. It sounds like you have an "open" ground in the windshield washer circuit. The W/W circuit is finding a temporary path to ground through the door switch circuit (don't ask me how, electricity seeks the path of least resistance). Once you close the door you lose the path to ground.
[sm=icon_cheers.gif]
Old Dec 20, 2007 | 11:36 AM
chvet73's Avatar
There is a ground wire that goes to a bolt on the bell housing. This wire is often mistakenly connected to the starter. It is the ground for both of the problems your having. Should be a black wire with a large ring terminal to fit over the bellhousing bolt. This was the first Corvette mysteryI solved on my car. It can drive you nuts until you find the wire.
Old Apr 6, 2008 | 07:01 PM
anzolv's Avatar
Thanks all for the help: To help others ,I found a short in the connector to the blower motor relay. One of the wires on the conector was touching the side of the relay causing the short. Who knew that the wipers, blower and doors were all connected.
Old Apr 6, 2008 | 11:49 PM
That little quirk of automotive wiring is what makes it so much fun to troubleshoot electrical problems.
Glad you found the problem and thanks for the update.
braveheart3158
Jul 24, 2012 09:57 AM
DryCreamer
May 5, 2008 05:03 PM
ru10707
Aug 28, 2007 06:46 PM
dan33470
Jun 3, 2007 09:19 PM
Bagpipingjake
Oct 9, 2006 05:44 PM
