removing split shafts
Old Aug 19, 2008 | 05:15 PM
YANKEECORVETTE's Avatar
Default removing split shafts
My 1986 needs new rear u joints on the split shafts. I was wondering if there is easy to pull them out as the C3 vettes are? . I wish any corner cutting w/o being a butcher. Have access to lift and any tools needed .Any input welcome.
Old Aug 20, 2008 | 06:45 AM
Default RE: removing split shafts
It is a pretty fair task. You have to take the torque struts loose and all the spindle mounts, as the hub assembly is not like the C3's. Be sure and mark clock rotation on bottom control arms since they are used to set caster and any other bolts that used in alignment. It is a good 2-3 hour job per side aside from installing u-joints. Check your hub assembly close for bearing roughness as it would be a perfect time to replace them if they are bad.
Old Aug 20, 2008 | 03:04 PM
Thank You Mech259.
Old Aug 21, 2008 | 11:10 AM
Your welcome. [8D]
mytoy
Feb 27, 2011 05:44 PM
rh04me
Jul 14, 2007 10:46 AM
cernigs63
Jan 24, 2007 12:45 AM
srizzutto
Jan 5, 2006 11:32 PM
GEORGE
Sep 5, 2005 10:58 AM
