ROUGH IDLE AT A STOP LIGHT!
WHATS UP YALL I'V NOTICED THAT AT A STOP LIGHT MY CAR TENDS TO IDLE ROUGH., BUT IF I PUT IT IN PARK SHE IDLES NORMAL, I REPLACED THE PLUGS AND WIRES (A/C DELCO) AND I ONLY RUN 93 IN IT, IM ABOUT TO DO THE FUEL FILTER BUT DONT HAVE A CLUE WHERE ITS AT! IM NEW TO VETTES SO IF ANY OF YALL HAVE HAD THIS PROBLEM PLEASE HELP! THANX YALL! MIKE
not sure where the filter is on the '92 but on my '87 it is on the frame rail just behind the right front tire. not too hard to get to. not too sure about the rough idle but come to think of it mine does it too sometimes.
Fuel tank additives are for maintenance purposes only. Techron is a very mild injector cleaner. If your injectors are really bad, it will not help. The cleaner we use will take paint off cars.
"how are the fuel injectors cleaned? How much should this service cost?
Dean "
Injectors are cleaned internally by means of a service kit that hooks up to you fuel system and uses a very potent cleaner to help dissolve carbon deposits that build up in the spray nozzle of each injector over time from engine heat cooking the fuel in the nozzle mostly from driving up with the engine hot and shutting off with the fuel having no place to go. [8D]
Dean "
