Runs bad when hot
Old Jul 22, 2016 | 11:39 AM
LeesSherman's Avatar
Question Runs bad when hot
I bought this low mileage (85,000) C4 in the spring and everything seemed fine. Now that summer is here, if the temp goes above 230, it will run OK at a steady throttle but does not like to accelerate, either from a stop or to change lanes, etc.
At a stop sign the car idles fine but when you push the throttle down (in gear or in neutral) the bucks, jumping between "I want to accelerate" and "I want to die".
Giving it 100% throttle does not help but as soon as you go back to steady speed it seems OK. I've only heard what sounded like a backfire one time.
It seems to average about 19MPG, I'm not sure if that is normal or not.
And like i said, below 225 it seems to run fine. I'm going to stop by a friends shop tomorrow and see if there are any codes stored.
Any suggestions on where I should be looking?
Old Jul 23, 2016 | 11:45 PM
The first thing I would do is check the fuel pressure. 230° does sound a little bit warm. Have you check the cooling system such as thermostat , lower radiator hose, etc.
kodiak7251@gmail.com
Aug 7, 2014 07:37 PM
bam
Apr 16, 2011 09:54 PM
white88
Aug 31, 2006 02:56 PM
imb1987
Aug 14, 2006 02:01 AM
parkit
Jul 25, 2006 02:10 AM
