Starting Problem
Old May 1, 2007 | 08:25 PM
  #11
Default RE: Starting Problem
No. That means the security system is enabled. The key reader that is built into the ignition switch is probably bad and not reading the proper resistance. There is a Pass Key bypass harness you can put in if you know the code for your key. Most locksmiths have a reader they can determine which code you have.
Old May 1, 2007 | 08:50 PM
  #12
Black86vette's Avatar
ORIGINAL: mech259
Got that. Good investment. Mine kept not reading the key. 25.00 from Midamerica. Ecklers has it also. [8D]
Old May 2, 2007 | 10:00 PM
  #13
95trplblkandtan's Avatar
no, my car does not start when the clutch is not pushed in...
Old May 2, 2007 | 11:36 PM
  #14
OK, when you say you have checked all the possiblities, what do you mean? Have you gone through the switch continuity check (cruise control switch), checked for voltage at the pin on the switch. There is also tests to actuate the cruise servo manually to see if it operates. Make sure you have a good vacuum source to the servo. There are several tests to perform which gets a little more complicated, to much to describe here.
Old May 3, 2007 | 07:25 PM
  #15
okay, no, i havent gone through those test, i checked the fuse, and i checked the vacuum lines, all connected and in good condition. I was thinking that it was the servo, but i have not done the manual test that you were talking about, are there directions posted somewhere?
fcoyne
Jul 22, 2007 11:27 PM
Phinallya90
Jun 14, 2007 08:57 PM
GREENSKIN
May 6, 2007 12:35 AM
Phantom
Dec 31, 2005 08:09 PM
NHRalph
Oct 18, 2005 09:55 PM
