sticky brake pedal 93 ruby
Old Aug 14, 2019 | 09:55 AM
espy1949's Avatar
Default sticky brake pedal 93 ruby
just did a little investigating on my sticky brake pedal issue. i applied the brakes (car off and cold) the pedal stayed down. while it was down i slid the master cylinder off of the booster and the pedal stayed down and the stop lights were still on. unfortunately theres no pedal return spring on the 93
i mite have to remove the booster and enlarge the mounting holes (tight fit) to allow a little wiggle room because connecting the pedal linkage was a struggle. my guess is if it was a struggle to connect it might not be perfectly centered causing resistence on the linkage thus not allowing it to return on its own
espy1949
Aug 15, 2019 09:42 AM
espy1949
Aug 13, 2019 04:43 PM
dr_maddox
May 12, 2009 11:22 PM
dr_maddox
May 9, 2009 07:25 PM
dr_maddox
May 9, 2009 12:12 PM
