sticky brake pedal problem solved
today i was pondering why the brake pedal wouln't return to its normal position.
i dropped the hush panel and using a mirror to guide me i sprayed penetrating oil on the vacuum booster to pedal linkage and pedal pivot point, operated the pedal in rapid succession, sprayed more penetrating oil, took it ourt for a stop n go cruise and all seems to function as it should. no more sticky pedal.
hopefully i got it. at 70 im not sure how many times i wanna go thru that aggravation.
