Sudden loss of power '1990 model'
Old May 4, 2007 | 08:47 PM
gtassios's Avatar
Default Sudden loss of power '1990 model'
This problem is intermittent and can happen at any time. I'll be driving along and then all of the sudden I'll experience a loss of power and the car stalls. I'll wait a few seconds and start it without any problems. I've had all the fuel injectors replaced, but that didn't help.
I would appreciate feedback from anyone that has experienced the same problem,
Old May 5, 2007 | 12:58 AM
Default RE: Sudden loss of power '1990 model'
The causes to that can be several different things. I would need to know if you are losing spark or fuel pressure, or injector pulse. It will be hard to tell without a trail to follow.
Old May 5, 2007 | 10:12 PM
mdsbch's Avatar
This used to happen on my 85 coupe and it tuned out to be a plugged catalytic converter that was causing it.
Old May 7, 2007 | 10:33 PM
AXE's Avatar
AXE
Had same problem in a trans am i used to have and it turned out to be electronic module in distributer. so you may want to check that out
alastysfupt
Jul 13, 2009 08:14 PM
pd1955
Sep 23, 2007 07:21 PM
texvette
Nov 25, 2006 04:03 PM
frank j
Nov 11, 2006 12:34 PM
dcd58
Nov 24, 2005 01:21 PM
