Timing Adjusment
Old Jul 1, 2007 | 09:50 PM
bigjohn's Avatar
Default Timing Adjusment
Dose anyone know if there is a way to adjust the timing on a 94 lt1. I have looked in the book on it and it dosn't say anything about the timing other than when you put the opt-spark back on. My car sounds like the timing is off when I try to crank it and it dosn't have near the power of other 94's and 95's that I have drove. The car only has 81,000 mile on it.
Old Jul 4, 2007 | 01:28 PM
JoeVetteman's Avatar
Default RE: Timing Adjusment
Hello,my friend. I think the LT-1 does not require any adjustment.It's possible you may need to do a tune up and change your opti-spark.Hope you find a solution.good luck.Your friend,Joe.
Old Jul 5, 2007 | 08:15 PM
bigjohn's Avatar
Thanks for the help. I found out that one of my cooling fans wasn't working and the engine was getting around 240 to 250 degree's causing the engine to lag power and strain real bad.
vetterz06
Aug 26, 2006 03:33 AM
yuggster
Aug 13, 2006 01:13 PM
jph
Feb 27, 2006 12:05 AM
josephgts
Feb 8, 2006 11:47 AM
jess_p
Nov 15, 2005 01:19 PM
