Trouble starting when hot
Old Oct 14, 2007 | 06:31 PM
  #21
brucek's Avatar
Default RE: Trouble starting when hot
Thanks for the note. I was thinking of replacing the injectors, surprised that it didn't help.
I have completed a major tuneup including replacing the OPTI spark, Cooland temp sensor, New plugs and wires.
I have noticed that it happens less frequent and is less of a problem when my fuel tank is near full?
Have you noticed the same?
Old Oct 14, 2007 | 06:34 PM
  #22
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Oct 14, 2007 | 06:44 PM
  #23
ORIGINAL: 89RIDE
our mechanic replaced a module (computer?) - he says it helped but still not 100%. From day one he felt it was the injectors.
FELT? He FELT?
A mechanic's feelings are just grand, ain't they?
I would have asked him how he feels about a guarantee of his work. See below...
Code:
[IMG]local://upfiles/5243/B1E3FDE75E3545668CB46ACC54184332.gif[/IMG]
Old Oct 14, 2007 | 06:47 PM
  #24
rshiver's Avatar
ORIGINAL: dfwgsx
okay guys i have this very problem,i had another thread started titled"Fuel Pump Relay"not knowing that this one was already started.I had a bit of black smoke puff out at start and so i was told as well as thought it was leaky injectors, so therfore i replaced them. So i tried replacing a few things in order to fix this annoying starting problem, so far NEW injectors(all 8), MAF, Ignition Control Module, FPR, Coolant temp sensor, I am really close to running out of money, i cant afford to keep spending all this money and still not fixing the issue that is at hand. PLEASE HELP!!!
I can't remember if this was mentioned in the other thread or not, but have you checked the fuel pressure?
Old Oct 14, 2007 | 07:46 PM
  #25
ORIGINAL: cwb
ORIGINAL: 89RIDE
FELT? He FELT?
Code:
Uh-huh...
Old Oct 15, 2007 | 07:27 PM
  #26
dfwgsx's Avatar
i will check it but it will be thursday before i can get a gauge. What should the pressure be idle, start whatever you need to know. LMK
Old Oct 15, 2007 | 07:39 PM
  #27
Around 35 lbs and more important, you should have a slight rise in pressure under a snap throttle.
Old Oct 15, 2007 | 07:55 PM
  #28
dfwgsx's Avatar
snap throttle?
Old Oct 15, 2007 | 08:08 PM
  #29
Stab the throttle with your foot or where throttle lever on throttle body is.[8D]
Old Oct 15, 2007 | 08:17 PM
  #30
dfwgsx's Avatar
oh okat thats what i thought but i figured i would make sure
