Turn signal blown fuse
Old Jun 17, 2007 | 09:11 PM
jph's Avatar
jph
Default Turn signal blown fuse
Anyone had a turn signal fuse burn out on an 89? I disconnected the back up light at the trans to eliminate that circuit. The fuse blows within minutes or hours after inserting a new one. Checked all the light sockets and checked for broken wires. Could it be the flasher or the turn signalswitch?
Happy FathersDay to all you dads.
Old Jun 18, 2007 | 07:26 AM
Default RE: Turn signal blown fuse
https://www.corvetteforums.com/m_35091/tm.htm, #2...
Old Jun 18, 2007 | 10:11 AM
dans87vette's Avatar
Yep, having similar problem. My tail lights blow a fuse when using the blinker. I found a thread on another corvette forum from over a year ago with a guy having the same problem. His ended up being a worn wire/connection in the steering column. Once he took the column apart and fixed it, no more problems. I have a week off from work in a couple weeks and that's exactly what I'm doing. I've check all connections, bulbs and wires I can get to and have found nothing, so I don't have much choice left. Another mechanic had suggested that is a fairly common problem with 80's gm vehicals that had tilt steering.
Old Jun 18, 2007 | 10:38 AM
jph's Avatar
jph
Let me know what you find, sounds like my next project also.
pirate
Feb 27, 2008 04:22 PM
Chunky
Jun 8, 2007 08:07 AM
chuck
Sep 7, 2006 01:23 AM
Pecemkr
Aug 31, 2006 12:41 PM
c3vetteman
Aug 24, 2006 01:27 AM
