vats system
Old Apr 26, 2014 | 02:22 PM
vettezero's Avatar
Unhappy vats system
Hi new to the forum I have a 93 C4 that I cant started I changed the battery and system wont disarm I and the remote is broken what can I do to start my car help please
Old Apr 28, 2014 | 05:19 AM
hcbph's Avatar
Default VAts
Have you tried unlocking the car at the door using the key? If it's off, then it could be the resistor on the key isn't being read. Try cleaning off the resistor and the slot in the ignition where it fits with alcohol or good cleaner.
If that doesn't work, then you can get or build a alternate resistor that plugs into the wiring instead of reading the key. If that works then you're done, if not then you have something else wrong.
You need to match your key up to the right value but this will override reading the resistor on the key: http://www.ecklerscorvette.com/catal...=vat&x=32&y=10
Old Apr 28, 2014 | 11:33 PM
vettezero's Avatar
Default vats system
unlocking the door didn't work have to try something else
Old Apr 29, 2014 | 09:01 AM
hcbph's Avatar
Default Alarm
My 86 does not have a fob for the alarm. You arm it using the power locks on the doors and disarm it with either the power lock button or using the key.
Did you use the power lock button in your test?
Unforunately that's about all I know on alarms other than they can be a pain if not working correctly.
Black86vette
Mar 31, 2007 09:30 PM
motomaniac1988
Mar 26, 2007 10:11 PM
Rocky
Jan 24, 2007 10:19 PM
CorvettePawnMan
Aug 26, 2006 10:43 AM
KYTiger
Aug 24, 2006 12:11 PM
