Will these wheel/tires fit a C4
Old Sep 16, 2020 | 11:37 AM
Frank Overbey's Avatar
Default Will these wheel/tires fit a C4
I have a 1995 C4 base model. I am currently running stock C5 spoke wheels with Rear 275/40/18 and Front 245/45/17 tires. They fit and perform fine with no mods. I just picked up a set of like new aftermarket ZR1 wheel copies off of a 1998 C5 convertible with Rear 305/35/18 and Front 275/40/17 Nitto street drag slicks. Anyone know or have any experience as to whether these wheel/tires will fit my C4 without modification?
Old Sep 18, 2020 | 09:14 PM
Well, I will answer my own inquiry. Yes they will without any rubbing and/or bottoming out. Car seem to be a little taller (I did not take measurements before installing them). The tires stick out about an inch further than before, with the rear being the most noticeable. This thing corners like it's on rails.
Old Sep 19, 2020 | 10:32 AM
My calculations show that the front is about 1/4 inch taller with this tire setup.
Old Sep 19, 2020 | 12:38 PM
I think it's more (I wish I would have taken measurements prior to putting them on). The front looks higher sitting in the car and the back looks higher from the outside.
Old Sep 19, 2020 | 01:58 PM
If the offset is different, that could affect ride height also. You might want to have the alignment checked.
scotth48
Mar 30, 2010 12:50 AM
Mille44
Jul 3, 2008 04:17 PM
87forme
May 9, 2007 08:28 PM
rhdaprato
Jun 2, 2006 01:57 PM
2002Z06
Corvette C5 Z06
Sep 23, 2005 07:08 PM
