6 speed
Old May 13, 2007 | 02:08 PM
electro blue's Avatar
Default 6 speed
I'm new to the corvette world.What dose a 6 speed skip shift eliminator do.
Old May 13, 2007 | 02:15 PM
95C4yourself's Avatar
Default RE: 6 speed
It keeps your car from automatically shifting into 4th gear at slow speeds. The skip shift was the General's great idea on how to keep the cars within emissions. So with out a skip shift el. or the help of someone that you trust to bypass the transmission will force shift into 4th from 1st at slow speeds.[:@]This will drive you crazy after awile!
Old May 13, 2007 | 02:23 PM
Default RE: 6 speed
this exactly what my vette is doing,how to I fix this problem, can I do it myself
Old May 13, 2007 | 02:32 PM
Default RE: 6 speed
You install a skip-shift eliminator, sometimes refered to as an iCAGS. They cost about $30 and takes half a minute to install (unplug the CAGS fitting on the side of the trans, install the iCAGS, plug the CAGs fitting into the other end of the iCAGS) but that is once you get under the car - requires ramps or a lift to reach it.
Old May 13, 2007 | 02:37 PM
Default RE: 6 speed
THANKS If I took the car to a shop or a dealer what would it cost approx.
Old May 13, 2007 | 03:20 PM
Default RE: 6 speed
Unless it's a performance shop I don't know of what shop would do it. I am lucky to have shops around here. It really isn't that hard to do. Disconnect one plug, plug in the eliminator and zip tie up out of the way.
1989 BLOWNCONV VETTE
Jun 17, 2008 06:33 AM
t88supra
Aug 8, 2006 05:38 PM
Tyler
May 19, 2006 03:24 PM
Patrick
Oct 9, 2005 02:25 PM
Richvette
Oct 5, 2005 12:39 AM
