ABS and traction control light
Old Sep 18, 2012 | 07:21 PM
  #11
Dave01's Avatar
Take a look at the removal procedure in the my previous post. The codes listed are typical of a bad EBCM. To look at codes:
http://www.stengel.net/diccodes.htm
Dave
Old Sep 19, 2012 | 09:16 AM
  #12
d69zcam's Avatar
I looked at the removal procedure, but first I did the codes. When all the codes came up, I didn't get the 1214 code. How do you interpret the codes? The numbers come up, but I don't know what they mean. I did call Brandon in Mo., and what a nice gentelman. He was leaving for a week in one hr. so he told me to call him back on the 24 of Sept. When I reset all the codes that came up on my Vette, no lights were on the dash. Then I took it for a drive and no lights or warnings came on!! What happened. I am new to all of this, so Dave01, can you explain to me your theory? I will be driving it for about 3-4 hrs. tomorrow in the mountains, so that will be a good test to see if the lights come back on. Thank you for all your help!
DuWayne
Old Sep 19, 2012 | 09:48 PM
  #13
Dave01's Avatar
DuWayne,
The lights will (most likely) return. When they do, you should write down all codes, including the history codes. If there is only one code, a C1242, then the problem is with corroded EBCM connector pins or ground lug connections (coming from the connector wires). Check/clean the grounds and unplug/plug the two connectors, multiple times to establish good ground connections. However, if you see codes C1287 and/or C1288 it's the swps (steering wheel positioning sensor). If this is the problem, take a look at this post; at the bottom of this page, there are many pictures and instructions for removing the SWPS.
http://forums.corvetteforum.com/c5-t...on-sensor.html
The most common code for a bad component in the EBCM is C1214. If you see that, it's probably time to send your module to ABS Fixer.
Old Sep 22, 2012 | 02:37 AM
  #14
d69zcam's Avatar
Dave01, the lights came back on my 01 Vette. How do you interpret the codes once you get them? What are the history codes? Thank you so much for helping me with this problem. If you don't fix the lights on the dash, will this effect the cars performance or anything mechanical on the car? I am new to this, but I want to learn about this.
Old Sep 22, 2012 | 07:24 PM
  #15
Dave01's Avatar
DuWayne,
This website lists the codes and what they mean:
History codes are codes that were set in the past. If the previous owner never reset the codes, yet fixed the problems they represent, the codes can be erased. However, if you erase all the codes and some or all return, that means that the problems still exist and need to be remedied.
What are you seeing for codes? Write them down and list them in your reply.
Old Sep 23, 2012 | 02:54 PM
  #16
d69zcam's Avatar
Dave01, here are the codes that came up.
60 IPC 1 code
58 SDM 4 codes
40 BCM 0 codes
28 TCS 6 codes
10 PCM 2 codes
AL RDCM 4 codes
BO RFA 0 codes
A6 SCM 0 codes
A1 RDO 4 codes
AO LDCM 4 codes
99 HVAO 4 codes
AO LDCM 4 codes
That's it. I have no clue what this means. Once you get the codes, I need to know what they mean, and how to reset them. Do you press the E/M button to clear them, and press the reset button?
Thanks so much for any help you can give me.
DuWayne
Old Sep 23, 2012 | 03:05 PM
  #17
d69zcam's Avatar
Dave01. how can you tell the difference between the hisory codes and regular codes?
Thank you,
DuWayne
Old Sep 23, 2012 | 09:44 PM
  #18
Dave01's Avatar
DuWayne,
There should be a more specific code listed after every category code that you listed. For example, see:
http://www.vetteweb.com/tech/vemp_09...r/viewall.html
Write those secondary codes down and then look at the website I posted, previously to see what they mean.
Notice that one of the D.I.C. displays shows a code with "H" after it. That indicates it is a history code.
Old Dec 10, 2012 | 11:30 AM
  #19
99VetteMikey's Avatar
With this great sites help I learned how to check the codes, they indicated the EBCM issue, I replaced the EBCM and the ABS issue was resolved then the check engine light issue and subsiquent codes showed the Passenger side Check valve needed replaced and this site again saved me a bunch of money telling me how to simply buypass it! Great website THANKS YA'll
metroaudiocraig
May 14, 2011 07:31 PM
ADavila
Aug 31, 2009 05:05 AM
2000redvette
Mar 7, 2009 11:11 PM
hardluck
Jun 24, 2007 12:56 AM
50annv03
Apr 19, 2006 05:56 PM
