Advice needed on repair/upgrades while subframe dropped
Old Aug 17, 2012 | 02:32 PM
ryking13's Avatar
Default Advice needed on repair/upgrades while subframe dropped
I have a leaking front main seal on the transmission and the dealership will have to drop the subframe to get to the engine and transmission, separate them and replace the seal. I am using a dealership for this because my understanding is this is quite easy to screw up, especially mounting the subframe back and getting it aligned correctly. I was quoted 12 hrs labor to replace the seal, and 2 hrs to do a 4-wheel alignment once the subframe is remounted for a total of approx. $1500 which I've been told is reasonable. My question is: while the engine and transmission are already going to be out, is there anything else I need to think about replacing or upgrading? This is a 2004 convertible with 52,000 miles.
Any help or advice is greatly appreciated.
Old Aug 20, 2012 | 01:24 AM
Dave01's Avatar
I had the same work on my car at the dealership for about the same price. I also had them do a drain/fill of coolant (should be done every 5 years).
Old Aug 22, 2012 | 03:18 PM
vettemanrob's Avatar
Im sure they will have to drain and replace the power steering and brake fluids as well.
Old Aug 24, 2012 | 04:29 AM
Tristaner's Avatar
ya surely they will drain and then replace the power steering and brake fluids ,because power steering also consists of oil , so it has to be drained.
Old Aug 24, 2012 | 08:05 AM
ryking13's Avatar
I'm not sure I follow you guys. This is a transmission fluid leak.
Old Sep 21, 2012 | 05:14 PM
Dave01's Avatar
What we're saying is that as long as your car is at the dealership, you may as well have maintenance stuff like fluid changes done.
ARMYSSG
Nov 9, 2009 07:26 PM
pewter2000
Oct 24, 2007 07:33 PM
Jun 4, 2007 10:23 PM
pookie16
Jan 18, 2007 08:11 PM
creed02
Aug 27, 2006 04:42 AM
