blower motor will not turn off.
I have a 98 Corvette, and tonight when I pulled it in the garage shut the motor off and remove the key the fan motor was still running. Can anyone tell me the problem? Please!
The first thing I would check would be the switch itself. Did you try all speeds on the blower? The second thing I would check would be to see if the ground circuit had been pulled to ground in the wiring harness someplace. Has there been any work done recently in that area?
