C5 will not start - need help.
Old Aug 10, 2009 | 09:06 AM
wayrod's Avatar
Default C5 will not start - need help.
I have a '99 C5 and it will not start. It went dead at a tfc light and re-started...a week later it went dead again and re-started...the next week it went dead and I had to call a tow. I can start it with starter fluid, but it goes dead. The fuel pump seems to be running...I can hear it in the tank. No codes presently. I did install the CLB...the wheel was locking intermitently...it was a shot...no change. The starter spins, but it is getting no fuel.
Old Aug 19, 2009 | 04:42 PM
vettemanrob's Avatar
Dont know if this will help but on my 02 when the ignition switch started to go out my car would die unexpectedly at different times ( on the highway, at a red light and so forth ). Once replaced I have had no more problems. It would also be hard to restart once it died. Hope I was of some help.
Old Aug 19, 2009 | 10:29 PM
partsman41's Avatar
My 84 did exactly the same thing,died and restarted a few times and then wouldn't start 'til I changed the ECM. Have you checked for fuel pressure? Have you checked for spark? A failing spark module could also act that way. Good Luck!
Ron
ktrixx
Sep 11, 2010 12:48 AM
95Vette
Aug 13, 2006 02:11 PM
MT USA 1
Jun 14, 2006 09:26 AM
vettey
Jan 21, 2006 02:25 AM
PHILC
Nov 20, 2005 11:25 PM
