check engine light
Old May 14, 2008 | 07:13 AM
gsb321's Avatar
Default check engine light
My car is a 1999 Fixed Roof Coupe. I have had problems with Delco batteries leaking and corroding the terminals. Recently my "Service ABS" & Service Traction Control" lights were on. As a check, I took the terminal wires off the posts, cleaned the terminals and reinstalled the cables. After a short ride, the lights went off and the ABS & TractionControl started working again. Now a few days later, the "Check Engine Light" is on. The mechanic at my local Chevy dealer has cleared the codes and told me he received a 5mV reference. He is still checking, but cannot determine the problem. I have thought about replacing the battery with an Optima battery and see if that helps. I would appreciate any information, if anyone has had similar problems.
Old May 14, 2008 | 09:36 PM
Dave01's Avatar
Default RE: check engine light
It sure sounds like your EBCM unit is dying. Check out my removal and install procedure on this page:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
It's the last procedure and gives you an idea what type of codes you can pull up. I believe your 97 doesn't have active handling, so that would explain why you didn't see "Servive Active Handling".
Good luck.
Dave
cmittag
Jan 20, 2007 02:36 PM
CEILIA
Sep 20, 2005 07:40 PM
CEILIA
Aug 20, 2005 03:12 PM
rmd1960
Jul 31, 2005 11:13 AM
gerald452
Jul 21, 2005 08:24 PM
