Check Engine Light on then off ???
Old Mar 28, 2006 | 05:26 AM
Karl Englund's Avatar
Default Check Engine Light on then off ???
Just bought 01 coupe 6 speed 34k on it. Check Engine light comes on then clears after 4 or 5 starts. Checked codes and says left bank lean, seems to miss up to 1200 RPM.
02 Sensor?
Which one?
Also seems to have alot of trannie noise. Is that normal?
First 6 speed and a little skeered!
Is it true I need to have all fluids done at dealer to be documented? Don't want to hurt resale.
Old Mar 28, 2006 | 06:38 PM
Default RE: Check Engine Light on then off ???
It could be a bad O2 sensor (happens a lot), but it is clearly just intermitant since it clears itself. I would do the drill for the easy things: run some injector cleaner through it, change the fuel filter, etc., in case that is it, and if recurs have a shop look at it.
Has the car been modified (headers, custom exhaust, cold air intake, etc.) or the ECM re-programmed in any way -- this is a common code to get in those cases and may not mean much: the stock tolerance range if very narrow -- I had the same code intermitantly on mine and just had the tolerance range widened slightly (after checking everything very carefully) and it when away and I have had no problems.
As to gear noise, I don't know how to answer you except: try to drive or ride in another one and compare. Vettes are not as quiet as other cars but no, there is not a lot of gear whine. If in doubt have it checked out.
Good luck.
Old Mar 28, 2006 | 08:33 PM
What code is it actually? P0??? Left bank lean could be several things, such as O2 bad, vacuum leak, etc. DOes it show Bank 1 Sensor 1, which is before the cat. Need to look at voltage readings through scan tool because it is what is called a heated Oxygen sensor and has probably 4 wires. Just replacing sensor might not fix your problem. If you do replace it, be sure and use an A/C delco sensor. Won't be real cheap, because the heated part, but Delco sensors are more active and gives you ECM (Computer) better fuel control. I would definitely let someone with a scan tool who is good in diagnostics check it for you. They would have the ability to look at whats called freeze frame data. This is a snapshot of all data inputs to computer at the time the code was set.
myronp22
Feb 8, 2010 10:52 PM
amvette
May 3, 2007 07:53 PM
cmittag
Jan 20, 2007 02:36 PM
rmd1960
Jul 31, 2005 11:13 AM
gerald452
Jul 21, 2005 08:24 PM
