Coil overs or Leaf?
Old May 26, 2022 | 08:11 AM
Rockitansky66's Avatar
Question Coil overs or Leaf?
Hi all, still undecided on coils or upgrading leafs? Car is a 2002 Z06 track only car running mostly intermediate/advanced speeds. Basically an OEM suspension except Bilstein DRM shocks, lowered and polygraphite bushings all around. Are coil overs worth the extra $1000 and hassle of installation? And if I did leaf spring upgrade, what lbs FR/RR would anyone recommend? Oh and Sway bars will be swapped also. THX Brian
Old May 26, 2022 | 02:29 PM
74HARLEY's Avatar
You asked some really good questions. Suspension upgrades in your case are very critical. The people who probably can help you the most are going to be running on the same tracks as you. Your driving conditions are nothing like a street car, and your car should be tailored to the specific conditions.
Old May 28, 2022 | 09:12 AM
It's important to be sure to maintain the balance of the car when you make suspension changes. So like 74HARLEY said, talk to others at the track.
Old Nov 4, 2022 | 02:54 PM
ProJoe's Avatar
I'm in the middle of a coil conversion on my C5. believe it or not, it's not that difficult.
As to your original question, when you look around at the strong track cars they're almost all on coils right? there's your answer. There are great entry level ones that will be slightly better than the OEM leaf setup and there are higher end track specific coils that will be significantly better. If this is really just a track car and not doing TT or some class racing where you must retain OEM suspension style, I would suggest coils for sure.
Old Nov 4, 2022 | 03:04 PM
David Covarrubias
Jul 22, 2019 02:48 PM
Jeff75
Oct 5, 2012 01:39 PM
C3 Starship
Oct 5, 2007 06:52 AM
bruiserman
Sep 29, 2007 09:05 PM
82Red
Feb 3, 2007 03:38 AM
