Ctek Charger Question
Old Feb 9, 2020 | 05:07 PM
Evan97's Avatar
Default Ctek Charger Question
I purchased a Ctek MXS 5.0 battery tender to keep my battery topped up while the car is in winter storage. Upon reading the instruction booklet and watching a few videos online from Ctek, the instructions state that if the battery is removed from the vehicle then simply connect the positive and negative cables to the corresponding battery terminal. However, if the battery is still connected in the vehicle, place the positive cable to the positive battery terminal, but connect the negative cable to a suitable ground point on the vehicle? Why do they recommend not connecting to the negative terminal if the battery is still connected?
Old Feb 10, 2020 | 12:31 PM
Maybe to prevent the possibility of a spark in an enclosed area around the battery since there may be hydrogen gas present. I've heard the same recommendation in relation to attaching jumper cables to cars.
I think the spark problem could be avoided if you connected the battery first before you plugged in the charger.
Robert A. Purinton
Aug 26, 2017 07:20 AM
bphein1980
Jul 3, 2010 11:37 PM
rippfan
Aug 27, 2006 08:33 PM
toroguy
Mar 29, 2006 01:05 AM
