Fuel Gauge Gone Goofy
Old Apr 4, 2011 | 10:36 AM
nebrgas's Avatar
Default Fuel Gauge Gone Goofy
Took my '97 with 10K for a ride after it sat all winter. After 10 miles with cruise on at 65 mph, the fuel gauge dropped from half a tank down to the empty peg and warning light came on for "low fuel". Other gauges remained ok, except tire pressure readings which were gone. Plenty of gas in the tank and after a couple minutes, the fuel gauge corrected itself and tire pressures were back. It did this several times and then it was ok. After a brief stop, I drove another 50 miles without incident. If the tire pressure readings weren't affected, I would say sending unit in fuel tank, but am puzzled. Any comments before I have it checked out? Thanks, Dave
Old Apr 4, 2011 | 02:51 PM
vettemanrob's Avatar
I would t ry to use some type of fuel system cleaner that you pour into your tank while it is full especially if it sat around all winter. Had problems like that a few years back and I poured in berryman fuel system cleaner and started using shell gasoline ( supposedly they use extra fuel cleaners or something like that ). Problem solved.
Old Apr 4, 2011 | 03:50 PM
nebrgas's Avatar
I did put a can of Seafoam in the tank last fall, but that was on top of a half-tank of gas that was a couple months old, and then I did not run the car until recently. Probably need to get some fresh gas in it along with a system cleaner.
Dave
Old Apr 5, 2011 | 09:20 PM
Dave01's Avatar
I pour in a large (16 oz) can of Chevron Techron at every oil change (once per year) and have never had a fuel gauge problem. This IS somewhat common, however - especially with 97-00 C5s.
donald
Dec 13, 2009 09:07 PM
buddym3
Jul 2, 2007 02:08 PM
KenHorse
May 28, 2007 05:26 PM
DSMKilla
Feb 13, 2007 11:51 AM
chaddeaux1
Sep 23, 2005 05:23 PM
