fuel gauge problem
Old Jun 16, 2007 | 04:59 PM
buddym3's Avatar
Default fuel gauge problem
fuel tank is full fuel gauge says empty
Old Jun 16, 2007 | 11:06 PM
jerrysullivan's Avatar
Default RE: fuel gauge problem
My '03 coupe did that. Selman chevrolet replaced the tank with the sender in it. ( warranty job )The right side tank I think........ good luck......... cjs
Old Jun 17, 2007 | 12:25 PM
Here's a link to a thread that may be of some help.
https://www.corvetteforums.com/m_31966/tm.htm
Old Jun 17, 2007 | 06:31 PM
alini's Avatar
I had that happen with 3/4 of a tank last week. I read numerous threads saying to put an additive in like Chevrons techron usually about $5 a bottle. I havent had a problem since, gauge read properly instantly.
Old Jun 24, 2007 | 08:21 PM
3434JJJ's Avatar
my gas gauge 0m my 99 c5 reads empty,low fuel etc. can anyone help/
Old Jun 24, 2007 | 11:25 PM
MY OTHER CAR IS A TO's Avatar
yea buy a GTO
Old Jul 1, 2007 | 06:49 PM
MY02VET's Avatar
You should only use Top Tier gasoline in your Vette! Chevron was the first gasoline certified as Top Tier and that is all I use in my '02. Put a bottle of Techron in your tank, however if your tanlk is currently full I don't know if it will mix into both tanks(yes your car has two tanks and each have a fuel sending unit.) You may want to run another bottle thru starting with an empty tank. The problem is that the fuel sending units are affected by the high sulfur content of many gasolines and the techron keeps them clean. It is a $500 plus job to get these sending units replaced at your dealership. Moral to this story is don't use cheap gas!
There are new parts specifically designed to stop this problem. If you would like the part numbers e-mail me as I would have to look them up.
Old Jul 2, 2007 | 07:27 AM
Anything that you put into your tank is gonna' go through the cylinders. What is 'techron'??? Chemically speaking???
Old Jul 2, 2007 | 07:42 AM
Just went to chevron site. PEA link is closed. A few other links were closed too.
Techron is the trade name for PEA - poly-ethyl-amine. Poly-ethyl is plastic, as in polyethylene. Works good dry,as in bushings. Amine group is ammonia. Good for fertilizer.
I guess it makes the plastic burn better when it goes through the combustion chamber.
Not in MY LT1.
Old Jul 2, 2007 | 02:08 PM
MY02VET's Avatar
Wow, I thought everyone had heard of Techron as it has been in Chevron gasoline for many years and they always advertise it. There is a big Techron sign on top of most Chevron gas pumps.
I never use any fuel but Chevron in my Vette if I can help it.
Speaking of LT1, my '96 had the LT1 and right by the gas cap there was a Chevron recommendation sticker placed there by the factory. I wonder why!
I am not a chemist but I do know the stuff works.
donald
Dec 13, 2009 09:07 PM
chrisdann1
Mar 4, 2009 03:10 PM
KenHorse
May 28, 2007 05:26 PM
DSMKilla
Feb 13, 2007 11:51 AM
chaddeaux1
Sep 23, 2005 05:23 PM
