grade of gas????
Old May 26, 2007 | 09:52 AM
mello33's Avatar
Default grade of gas????
What is the best grade of gas to use in a 2004 vette?
Old May 26, 2007 | 02:14 PM
Default RE: grade of gas????
The more mods you have made, the higher octane you will need. Personally, I would recommend goin' into the 90's, and stay away from the 80's.
Old May 26, 2007 | 06:33 PM
Dave01's Avatar
I use Arco and Mobile (91 octane) and have never had any problems.
Old May 26, 2007 | 06:43 PM
pewter2000's Avatar
i personally don't believe in anything lower then 91....unless it's for my lawn mower...
Old May 27, 2007 | 02:18 AM
chargedvette02's Avatar
Shell V-Power all the way.
Old May 27, 2007 | 07:17 AM
I have never put anything but premium (91 or 93 octane) in my vette even when stock. I understand the ECM will back off timing if it detects lower octane fuel but why make it do that and take the chance? The "premium for premium" is so small -- not sure it needs it but as I said its never been fed anything different and I never had any problems.
There is one station around here that sells 103 octane racing gas ($3 gallon above premium) and I ran one tank of that but it didn't make much difference with the stock tune.
I do know my 'vette puts out more power with higher octane gas and when re-tuned to use that octane (my shop played with it a bit) and that when running that fuel, with that tune, it can pick up a few tenths (gets into the 9s on drag radials, etc.) but since that grade is not commonly available I stick with a tune for 91 octane.
You can buy small bottles of octance enhancer at the auto store - STP and so forth sell them. One or two in a tank are worth several points of octane (I think the fine print on the bottles tell you how to calculate the gain). If you are in doubt about your tune and need for premium, you can put a couple of bottles in and see if it makes a difference. By the way, that stuff tunes the tips of your spark plugs a faint orange but seems to do no other harm.
Old May 28, 2007 | 12:36 PM
mello33's Avatar
Thanks!!!!
chuck
Mar 7, 2010 05:42 PM
ken93vette
Aug 6, 2007 04:39 PM
brians84vette
Sep 9, 2006 02:17 PM
john
Sep 3, 2005 03:48 PM
blbcklt1_tb
Jul 31, 2005 03:11 AM
