Headlights will not stop!
Old Feb 9, 2006 | 10:03 AM
HRS84VETTE's Avatar
Default Headlights will not stop!
My 84 Vette is having headlight problems. When the lights are turned on the motors will not stop running once the headlights have moved to their opened or closed position. Sometimes the right one works like it is supposed to, but the left one continues to malfunction. Is this going to be the headlight actuation module, a relay, or both? If so, where is the headlight actuation module located? I have found the relays, but as of yet been unable to locate the actuation module. Any help here would be appreciated. Thanks, HS
Old Feb 10, 2006 | 04:01 AM
Chris_N5CWM's Avatar
Default RE: Headlights will not stop!
It sounds to me like the typical C4 headlight issue!
Refer to this post for the info on parts and rebuild procedure.
https://www.corvetteforums.com/How_d.../m_4006/tm.htm
Old Feb 12, 2006 | 10:40 AM
Chris is right. Probably the nylon gears are stripped in the motor.
BB66
Apr 16, 2013 07:21 AM
rvitale
Nov 20, 2007 11:56 AM
wtrrescuer
Jul 21, 2007 07:17 AM
92VETTE
Jan 7, 2007 10:35 AM
hircc
Jun 20, 2006 03:13 PM
