No crank issue
Old Aug 7, 2025 | 07:12 PM
spina74's Avatar
Default No crank issue
Hey guys, I'm kinda out of ideas here. I bought a 99 base with a no crank issue. Previous owner said the ignition switch was replaced but still didn't fix it. It will start and run with the key on and jumping it at the tdr. I replaced the tdr relay and ignition switch, and jumped the neutral safety switch (M6)with no luck. All I get is a click by the passenger side foot area. Searching online it seems mostly everyone's issue is the ignition switch. Any other ideas?
Old Aug 8, 2025 | 02:39 AM
Welcome to the forum. Hopefully someone will come up with some helpful ideas for you.
Old Aug 8, 2025 | 05:04 AM
Welcome to the Forms. I hate gremlins too. If you have exhausted all your options by doing all the obvious, an open contact somewhere. You can do the bypass idea and run a new wire from the ignition switch or the safety switch if there is power there to the starter if the open connection cannot be found. Sometimes that's what you do when you can't locate the open contact. Or keep tracing the existing circuit. Good luck, That's what I would do if I had that issue.
Russ544
Aug 21, 2023 12:57 AM
Russh
Feb 8, 2023 09:40 PM
TJL74Vette
Jun 20, 2007 09:12 PM
weteyett
Dec 26, 2006 09:29 AM
phantomrt
Apr 29, 2006 11:58 PM
