OXY SEN Fuse keeps blowing....
Old Jan 14, 2024 | 01:20 PM
Rockitansky66's Avatar
Default OXY SEN Fuse keeps blowing....
Hi all, I have a 2002 track car that keeps blowing the OXY SEN 15amp fuse whenever I turn the key to start. I have long tube headers and have only the upstream flat 4 O2 sensors. The car will run fine but as I scan using HP tuners scanner, the bank 2 sensor 1, reading are fine at cold start up then go low volts after it heats up. Bank 1 sensor 1 reads good at around .440 volts but pax side goes anywhere from .200 to .900.
Any suggestions as to where I should start with chasing down this probable short? THX!
Rocky
Sep 27, 2007 04:24 PM
dans87vette
Jun 10, 2007 12:00 PM
MT USA 1
Jun 14, 2006 09:26 AM
imb1987
Oct 28, 2005 09:01 AM
jeepxj
Jul 5, 2005 07:09 AM
