Hi all,
I start my 99 C5 coupe and she idles nicely, five minutes later she misses and wants to stall. It has caused me to not be able to pass e-check because my converters won't ready up. Here is what I did before the problem started. Changed plugs and wires, cleaned MAF and throttle body with CRC kit. Also here is my confession, I cut corners on the wires and bought E-Bay $29.99 red ones (can't remember name). Could it be the cheap azz wires?
I would check the thermostat and see if its reaching 160 degrees or more, if not it stays in open loop.and check for stored codes.hope this helps, good luck
The thermostat never crossed my mind. I am just getting her out of storage (she went in with this problem) and will check on this first thing. TY for your response.
Problem solved, I couldn't get the plug wires out of my mind because I was so mad at myself for being a cheapskate and buying BS wires. JDMspeed Red wires to be exact and I highly recommend to NEVER buy these. I learned my lesson. Here is a picture of what caused this mess. The connector at the coil broke off. Bought Summit Racing Red 8mm SUM-867828R wires and she runs like the day she was born. Thanks to all who replied and I hope this may help someone who may have bought these wires.....perheiro
