rough idle after warm up
Old Mar 25, 2022 | 12:41 AM
perheiro's Avatar
Default rough idle after warm up
Hi all,
I start my 99 C5 coupe and she idles nicely, five minutes later she misses and wants to stall. It has caused me to not be able to pass e-check because my converters won't ready up. Here is what I did before the problem started. Changed plugs and wires, cleaned MAF and throttle body with CRC kit. Also here is my confession, I cut corners on the wires and bought E-Bay $29.99 red ones (can't remember name). Could it be the cheap azz wires?
Old Mar 25, 2022 | 01:34 PM
My guess is that when it goes in to closed-loop after warm up that there is something wrong with the computer.
Old Mar 26, 2022 | 10:59 AM
I would check the thermostat and see if its reaching 160 degrees or more, if not it stays in open loop.and check for stored codes.hope this helps, good luck
Old Mar 27, 2022 | 01:44 AM
perheiro's Avatar
Well I am praying you're wrong 73shark. I am just getting her out of storage and will check codes when settled. TY for your response.
Old Mar 27, 2022 | 01:46 AM
perheiro's Avatar
The thermostat never crossed my mind. I am just getting her out of storage (she went in with this problem) and will check on this first thing. TY for your response.
Old Mar 30, 2022 | 09:21 PM
perheiro's Avatar
Problem solved, I couldn't get the plug wires out of my mind because I was so mad at myself for being a cheapskate and buying BS wires. JDMspeed Red wires to be exact and I highly recommend to NEVER buy these. I learned my lesson. Here is a picture of what caused this mess. The connector at the coil broke off. Bought Summit Racing Red 8mm SUM-867828R wires and she runs like the day she was born. Thanks to all who replied and I hope this may help someone who may have bought these wires.....perheiro
doc18015
Aug 30, 2009 01:53 PM
bari_09
Sep 18, 2008 06:57 PM
lbelew
Aug 6, 2007 09:08 PM
dean
Jan 10, 2007 09:15 PM
92VETTE
Jan 7, 2007 10:35 AM
