Squeek in Front Suspension
Old Nov 25, 2007 | 11:56 PM
jbihl's Avatar
Default Squeek in Front Suspension
I have a 2000 conv. with 73K miles. The car has never been on a track or abused in any way. It hasn't been driven on dirt or gravel roads or in dusty conditions either.
Recently, after the weather cooled off, I have noticed a squeek in the front suspension. After the car warms up the squeek disappears. Is the a common problem? Are the ball joints shot or is it the cold rubber suspension bushings squeeking?
If it is the rubber, can silicon spray be used to lubricate them?
Old Nov 26, 2007 | 06:39 AM
jerrysullivan's Avatar
Default RE: Squeek in Front Suspension
Maybe just a pulley drive belt? cjs
Old Nov 26, 2007 | 07:28 AM
ORIGINAL: jbihl
Silicone would be the first diagnostic tool for me. Won't make a mess to draw dirt either. I WOULD make sure to try to get only one spot at a time, to try to isolate the squeek (and allow time for it to get in to each spot).
Old Nov 26, 2007 | 01:39 PM
Curious George's Avatar
It may be your sway bar bushings. I have a '99 w/ 73k and just replaced the front / rear sway bar bushings and it took care of my "little sqeaks". The OEM bushings get dry and will sqeak.
CG
Old Nov 27, 2007 | 10:10 AM
pewter2000's Avatar
Had the same "squeeks" every time I drove through the twisties on the way to the coast...had ALL the bushings replaced with Energy Suspension bushings under warranty (before it ran out *pheew*)...NO MORE SQUEEKS...[8D]
DeepCrush
Nov 28, 2012 10:41 PM
82Red
Feb 3, 2007 03:38 AM
stlvet
Sep 26, 2006 01:57 PM
72 vette
May 10, 2006 01:52 PM
jackson5
Dec 1, 2005 11:57 AM
