Corvette C6 Forum 2005+
Fuel pressue / Hard to start
Old Nov 24, 2019 | 08:50 PM
SXGT's Avatar
Default Fuel pressue / Hard to start
My stock LS2 is hard to start when it gets cold outside. All summer the car is fine but when cold weather moves in it is as if there is no pressure in the fuel rails and the cars takes extra cranks to start. The battery is good, put in a brand new Fuel Pump relay and it made no difference. So I am not sure what to do from here. If the car sits for more than 30 - 40 minutes I have this issue. If i turn the car off for a minute and start it, it fires up like normal so thats another reason I think pressure is maybe leaking off the rails, but this is ONLY an issue with cold weather.
Old Dec 14, 2019 | 09:54 PM
Check the fuel pressure and see if it holds when you shut it off.
Old Apr 24, 2020 | 09:43 AM
2fast2c's Avatar
Sounds like a choke problem ot ignition module
Old Apr 24, 2020 | 10:14 AM
Can probably move both of those out of the picture since it's fuel injected.
rodman
Sep 27, 2023 08:49 PM
Tommy Garguilo
Apr 24, 2020 09:53 AM
88redvette
Jan 20, 2007 05:35 PM
Bagpipingjake
Jul 25, 2006 10:11 AM
94blackC4
May 12, 2006 01:23 AM
