Corvette C6 Forum 2005+
The importance of a good tune
Old Jul 10, 2012 | 10:28 PM
AutoWiz's Avatar
Default The importance of a good tune
did you know that if you just bolt a cold air intake to your corvette without tuning it, the car will actually loose performance, not gain it. when you change the diameter and shape of the intake, it changes the way the air flows across the mass air flow sensor, and it needs to be recalibrated so it reports the right amount of incoming air to the vcm. and it is the same situation with the exhaust. and don't fool yourselves thinking the vcm will adjust and trim itself. the vcm is only self adjusting when it is in closed loop. and it can only operate in closed loop when the airflow across the maf is stable. the second you stab the gas pedal, the first thing that happens, before the motor climbs in speed, the vcm switches to open loop and relies on its base programming. and open exhaust and intake without a proper tune will make an ls or any other motor go dangerously lean at wot.
mrhaney
Apr 7, 2013 10:42 PM
hardluck
Oct 15, 2007 11:18 PM
JOFO17
Nov 24, 2006 01:04 PM
white88
Aug 2, 2006 01:59 AM
djgershom
Sep 20, 2005 10:43 PM
