Power steering pump shaft pulls out after hard acceleration??
HELP!!! I have a 2006 ZO6 with a Magnuson charger at 16lb boost LPE lower end build with 874hp 1023torque. Has ATI 10 rib pulley system. On a hard acceleration it pulls the power steering pump shaft out of the pump just enough to jump the belt. went through 2 pumps and a new OEM bkt to figure out what was happening. now the 3rd pump is pulled out 1rib and destroying the belt. Thanks in advance for your help!
I becomes an alignment problem if I run the car hard then it pulls the P/S shaft out of the pump. I have replaced the pump 2 times with new OEM pumps from the dealer. After a hard run it will pull the shaft from the pump not the pully from the shaft.
