Power steering pump shaft pulls out after hard acceleration??
Old 04-19-2019, 10:48 AM
motorin.427's Avatar
Default Power steering pump shaft pulls out after hard acceleration??
HELP!!! I have a 2006 ZO6 with a Magnuson charger at 16lb boost LPE lower end build with 874hp 1023torque. Has ATI 10 rib pulley system. On a hard acceleration it pulls the power steering pump shaft out of the pump just enough to jump the belt. went through 2 pumps and a new OEM bkt to figure out what was happening. now the 3rd pump is pulled out 1rib and destroying the belt. Thanks in advance for your help!
Old 04-22-2019, 09:23 AM
Welcome to the forum. Sounds like an alignment issue.
Old 04-22-2019, 11:22 AM
I becomes an alignment problem if I run the car hard then it pulls the P/S shaft out of the pump. I have replaced the pump 2 times with new OEM pumps from the dealer. After a hard run it will pull the shaft from the pump not the pully from the shaft.
Old 04-22-2019, 08:44 PM
How far out of the pump does the shaft come out? It sounds like there's something inside the pump, such as a retaining ring, that's breaking and allowing the shaft to move.
Old 04-23-2019, 03:38 PM
About the distance of 1 rib, it will jump and self destruct if you keep driving.
Old 04-24-2019, 02:48 PM
Still sounds like something is failing inside the pump that keeps the shaft retained. Probably going to have to disassemble it to see what it is.
mypetu39
05-25-2015 12:08 PM
614mobile
09-02-2008 12:12 AM
gigabyte
11-08-2007 04:36 AM
blueshark
12-26-2006 11:45 AM
stlvet
10-28-2006 06:38 PM
Quick Reply: Power steering pump shaft pulls out after hard acceleration??
