1985 corvette
Old Nov 3, 2006 | 11:22 PM
jec327's Avatar
Default 1985 corvette
still trying to get my vette where I can drive it, still popping in the fresh air intake, but idles a little better when I unplug the MAF sensor, but not much, don't know if there is a connection there. Please advise.
Old Nov 11, 2006 | 12:39 PM
Crash's Avatar
Default RE: 1985 corvette
not sure what you have done to fix it , but it could be anything like bad spark plug wires , cap , plug wires in wrong order, Need lots more info to help you out.
Old Nov 12, 2006 | 09:22 AM
Have you put a vacuum gauge on it? Popping in the intake means one of a couple of things, either cylinder is firing when intake valve is open or exhaust valve is not opening after combustion. Vacuum gauge should be steady at idle, not fluctuating. Sounds like either a timing issue or a lean misfire. Have you had injectors cleaned?
Old Nov 12, 2006 | 12:32 PM
jec327's Avatar
I bought the whole intake manifold injectors and all from a salvage yard, then ultrasonic cleaned them before I installed them, all I used was the injectors on my car, not the manifold. They have a good even clicking sound all around, and good resistance on all of them. I also used all new o- rings. Have not put a vacuum gauge on it , where should I put the guage to get good results?
Old Nov 12, 2006 | 01:25 PM
On a intake manifold vacuum source.
jec327
Nov 1, 2006 12:25 AM
jec327
Oct 30, 2006 01:11 PM
jec327
Oct 27, 2006 11:08 PM
jec327
Oct 7, 2006 06:33 PM
vatpitt
Jul 11, 2006 10:52 PM
