bad speakers
Old Apr 14, 2008 | 11:04 PM
harey1's Avatar
Default bad speakers
I have a 1995 vette coupe that has 2 bad front speakers.This is a Delco non bose system.The speakers are delco also.The problem is the factory Delco speakers are 10 ohms.All I seem to be able to find in the after market are 4ohm and under.If Iuse the lesser 4ohm speaker on my stock system will it cause harm?
Old Apr 15, 2008 | 01:07 PM
riley's Avatar
Default RE: bad speakers
I don't know anything about the stock system but generally speaking, yes you can use the 4 ohm speakers. Having said that, let me warn you that in some instances the power amp may overheat due to the additional power output with the lower impedance load (the speakers). This overheating may result in component failure.
I haven't shopped for speakers in a long time but it seems like you should be able to find some 8 ohm speakers.
Old Apr 17, 2008 | 10:05 PM
harey1's Avatar
Thank you for the info.
white88
Aug 31, 2006 02:56 PM
blueshark
Aug 1, 2006 01:52 AM
raisinbran
Jun 20, 2006 11:25 AM
jeffc5
Jun 16, 2006 10:01 AM
50annv03
Apr 20, 2006 12:10 PM
