Check engine light
Old May 6, 2007 | 11:39 PM
chargedvette02's Avatar
Default Check engine light
It has come on before and then gone away for months. I was just wondering why this would happen? Possible bad O2 sensor? The car drives normal when the light doescomes on, no black smoke no gray bluish smoke nothing out of the ordinary except the check enginelight is on.
Old May 7, 2007 | 09:18 AM
extanker's Avatar
Default RE: Check engine light
without a code you could change HUNDREDS of things before its fixed
Old May 11, 2007 | 11:25 AM
Tkul's Avatar
I know that with my 01 that if I do not put the gas cap on properly (let it click at least 3 times) I will get a check engine light. Once I put the cap on "tight" the light will turn off after a few restarts.
Old May 11, 2007 | 09:12 PM
Figured it out, wasnt the gas cap. Cleared the codes and it made the check engine light go off. Something about voltages.
cmittag
Jan 20, 2007 02:36 PM
CEILIA
Sep 20, 2005 07:40 PM
CEILIA
Aug 20, 2005 03:12 PM
rmd1960
Jul 31, 2005 11:13 AM
gerald452
Jul 21, 2005 08:24 PM
