Cruise Control help
Old Sep 26, 2007 | 10:10 AM
alive69's Avatar
Default Cruise Control help
Stock 90 Coupe: Went to Flagstaff in June. Used cc out and back. Parked car untill last week when we went to Effingham Funfest. ( Elvis is alive, he justuses a new name!!! ) Cruise would not work. Once there I checked the fuse andall the vac. lines I could get to ( notbehind the inst. panel ). Talked to a Calloway mechanic. He said vac. canister probably NOT the problem. Anyone had this issue before? Need some ideas please. Thanks, jack
Old Sep 26, 2007 | 10:13 PM
Default RE: Cruise Control help
Had the same problem with my '87. It was a vacuum line to the pot up by the drivers side headlight that had become loose and was split by the headlight going up and down. Was a PITA to find. Not much help but it's all I've got. Good luck with it. Cheers
Old Sep 29, 2007 | 08:41 AM
alive69's Avatar
Thanks blueshark, I've checked about every line, except the one going thru the firewall,and no luck yet. I'll keep looking. J
Old Sep 29, 2007 | 03:34 PM
Another thing I found on mine that may have contributed is the heater valve was shot and the diaphragm inside was leaking vacuum. so many places so little time. Good luck with it. Cheers
LS77L82
May 16, 2007 03:25 PM
mraaron895
May 14, 2007 03:35 PM
95trplblkandtan
Jan 16, 2007 01:14 AM
harleyboy52
Dec 17, 2006 12:04 AM
knob
Jun 16, 2006 09:56 AM
