Headlights intermitent dimming
Old Oct 7, 2005 | 02:36 PM
99hdtop's Avatar
Default Headlights intermitent dimming
hey guys,
Has anyone ever had their headlights go dim for about 1 second then right back to normal? It almost looks like if you put a load on them just for a second. It happens going down the highway or just cruiseing around. No pattern, just does it then it's over, and it will do it a few times in a 20 mile drive. Does it every morning going to work. I have checked the grounds on the frame up front on both sides and they are all clean.
Thanks for any help.
Old Oct 19, 2005 | 10:08 PM
crvttbass's Avatar
Default RE: Headlights intermitent dimming
That's a good one. Did you ever watch the voltmeter when it does this to see if there is a drain somewhere? It would be a good place to start. Kinda hard when it only does it for a second but if you could catch it, it would tell you if it's in the lighting system or a problem with something else. If you can't watch for it have a passenger watch the numbers steady while you watch the road.(recomended) Good luck
HPJUNKE
Jan 9, 2008 11:29 AM
tripleblack99
Jul 8, 2007 10:26 PM
tripleblack99
Apr 9, 2007 07:19 PM
bobbyj
Sep 25, 2006 11:07 PM
bobbyj
Sep 22, 2005 12:45 AM
