HELP!!!! Dead Battery
Old Feb 24, 2008 | 05:54 PM
monterey06vert's Avatar
Default HELP!!!! Dead Battery
I went to start my car and the battery was low. I hooked up the jumper cables as shown in the manual. The voltage said 13.6 and so I pushed the button. The car shutdown and 10 seconds later booted back up. I pushed again and it did the same. Then all of the electronics and lights came on, but still would not start. I shut the hood and the doors and the battery died completely. I can't get in the car at all. Any suggestions before I call the dealer tomorrow. BTW my car is an automatic.
Old Feb 24, 2008 | 06:50 PM
YANKEECORVETTE's Avatar
Default RE: HELP!!!! Dead Battery
Is this a '06?. I went through some GM service notes and found a very common problem.The under the hood lamp tends to drain the battery. Many theories on the facts. If you can get back in your car try to pull the wire on the lamp. Charge the battery and try again. If this car is under warranty bettergo withthe hook back to the dealer.
Old Feb 25, 2008 | 08:07 AM
Yes, it is an 06. I am dealing with the dealer today. Thanks for the reply.
Old Feb 25, 2008 | 03:47 PM
Please reply when you get your car back, I would like to know what happened for future reference. thank you
Old Mar 2, 2008 | 10:28 AM
Sorry took so long. It was a dead battery from not being started in 3 weeks. I will start at least once a week from now on. The dealer had to reprogram the convertible top. They did cover the battery under the warranty. The locksmith was able to pry the window open with an inflatable bag and use a pole with a hook to pull the handles on the floor that open the doors. It took him about 5 minutes. Thanks for your post.
Old Mar 6, 2008 | 02:15 PM
I recommend buying a trickle charger and plug it in when the car is not in use. I installed a Solar model 1002 for $40 and its small enough that it attached permently to the battery.Works great.Also Mid America Motorworks has a emergency entry access system for $30 part # 634-149, if you want go the extra mile. Good Luck.
Old Mar 7, 2008 | 10:13 AM
Thank you so much. These forums are great because of helpful people like you.
Old May 5, 2008 | 08:48 PM
bombs's Avatar
Yes this is great, I've got an idea for i also a very busy person and sometimes i forgot to start my car at least once a week and to clean the auto body parts for a week. thank you again.
billger
Jul 21, 2007 06:24 PM
RudeDog
Jul 1, 2007 04:38 PM
rippfan
Aug 27, 2006 08:33 PM
06 Vette
Aug 23, 2006 07:51 PM
Lee Willis
Feb 13, 2006 09:23 PM
