Knock Module
yes it has one, and no you dont want to "upgrade" it the reason its there is for detonation purposes, it retards your timing up to 22* depending on if it hears detonation(a result of your timing being too far advancedcausing the pre-ignition) other factors can contribute like heat and air density but not as often as timing
one other thing i for got to mention, it is very sensitive(so sensitive in fact, that you can tap the block or exhaust with a small 6" screw driver and it will retart the timing) so im not sure what your getting at??? but i hope this helps you
